BlazerBill
- Mar 24, 2023
- Texas
- Billy
- Chevy K5 Blazer
‘83 K5/350/4wd question: Please confirm my wiring/splicing is correct per the Haynes manual schematic. Tan wire from dash oil/choke indicator through firewall to new factory style oil psi sender (at distributor) spliced into dark blue wire to the oil psi switch and spliced with Lt blue wire to one wire from switch. The other wire from switch (pink/wh stripe) through firewall to fuse block. Basically, I need to know if the Tan (from idiot light to sender) spliced to DK Blue (from switch) and LT Blue (from choke) to DK Blue splices are correct. My understanding: the choke, oil sender and switch are tied together. If the sender doesn’t see oil press, the switch won’t close and won’t allow the choke heater to operate preventing engine start. Is this correct? Thanks, everyone!
