1980 C10 Cruise Control Switch 407437
legopnuematic
Licensed Junk Dealer
MO
Spencer
@Bextreme04 you have a GMT400 cruise setup on your truck don’t you?
Yeah, I have the rostra retrofit stalk and two relays converting the signals to the correct input for the GMT400 module. It only needs the 4 commands from the stalk and a VSS signal to function. Finding the correct cable to run from the module to whatever carb/EFI setup you have will be the hardest thing.
I actually haven't had it working on the road yet, still sorting out the wiring and swap things. I keep getting side tracked with house projects and other vehicle things that jump the line.
unimogguy
