Silver Square
- Jun 9, 2024
- Fayetteville, GA
- Jason
- Sierra Grande 15
I've got a set of 1970s Western Cyclone II wheels for my truck. These use the shank lug nuts with a washer. They are 6x5.5, not unilug. I thought I had a matching set, but one of them is slightly different. It's got an "RI" cast into the inside of the wheel next to the "15x10" casting. This one oddball wheel also has much more shallow lug nut washer "cups" for lack of better term. The other 3 wheels, I can set the washer down in the cups, or whatever that little recession that they sit in is called, and they won't move around when I push on them with my finger. The oddball wheel, the washers will slide all around freely. The "cups" are there, just very shallow. Is this wheel safe to use?
