YakkoWarner
- May 29, 2024
- Central Texas
- Wolf
- R2500 Suburban
I took my 1989 2500 Suburban in to get stuff done, got it back and its been running great. Steering wheel doesn't feel like its going to come off like a Loony Toons skit anymore, no check engine light staring me in the face, no Spyhunter level smokescreen out the back at speed over 55 MPH, etc...
And then I park at work, realize I need to move over a few inches because the lines in the parking garage are too badly faded to see until you exit the vehicle. Go to start up, it grinds very slowly for a second, then I get a reverberatingly loud bang (not a backfire). I ended up losing 3 hours from the work day crawling under there - pulled the inspection cover and the starter gear is still engaged to the flex plate but just barely - the teeth look almost edge to edge instead of cleanly meshing. Jiggling it around got the starter bendix to retract. I very slowly bumped the starter to see if it would engage/disengage, it did and the engine rotated slightly - enough for me to find a series of chipped (but not completely broken off) teeth on the flex plate. I threw on the a low-cost rebuilt starter (only one in stick within walking distance of work), took out the starter shim to hopefully get a better engagement and it did start up, but very noisily. Ran it home, came back to work in my Mazda. It would not even try to engage - could hear the starter motor run but no engagement at all. So tomorrow I get to have it towed back to the shop - I'm just trying to figure out what the heck I did wrong. The shop did not touch anything on the bottom side of the engine with the work they did (other than change out the oil which got contaminated with coolant when they took the intake off) - it was all top end stuff. I'm sure I'm in it for at least a new flex plate, probably another new starter, and cables from battery to starter/starter to junction box since they looked pretty crunchy on the bottom end from being right under the exhaust manifold. My overriding question is how to I prevent a repeat....
