WFarm
- Jan 11, 2023
- Central Virginia
- Paul
- K5 Blazer
I have an intermittent leak from my transmission that puzzles me. It’s a TH350 behind a 454 and driving a NP203 transfer case in my 75 Blazer. Transfer case is stock therefore full-time 4WD. Everything drives fine with no issues. The only thing I’ve done to the transmission was replace the filter and what fluid I lost in doing that. That was done last summer. I installed a Lube Locker pan gasket and there is no evidence of any leakage at the pan.
Months will go by and not a drop will be on the floor where it’s parked, then one day there will be a small puddle (couple of tablespoons?) under the transmission. It’s coming from where the kick down cable attaches. I figure a new seal may be needed but what puzzles me is why it only leaks occasionally.
The last leak occurred after I returned from the Cruise In last Saturday. Temps in the 80s, drive time maybe 20 minutes each way. Have driven quite a bit longer distances and not had leakage so not sure what’s up.
