Cab swap 2wd to a4x4 frame
matt1228
Siouxfalls sd
matt
Hey guys I’m at a loss here I swapped cabs on my 86 k10 short box and don’t remember where this wire goes tanish wire with black stripe comes from bulk head under hood I’ve pulled the one off my old cab bc the new cab it is cut off idk if I did it???? Any help would be appreciated
Turbo4whl
Downingtown, PA
Wayne
Could be the tachometer trigger wire. Did either the new or old cab have a tach?
83Stepper
Massachusetts
Chad
That bulkhead connector is all engine bay related accessories and components. That should be pink and black, color is faded. By the connector, looks like tach connector at the distributor cap.
77Dmax
vt
Joe
Oil pressure is blue.
GorillaHumper
