88 Suburban Barn Door Alignment
annettemarie
Cookeville, Tennessee
Annette
Chevrolet Suburban V10 Silverado
I just installed new weatherstripping on my rear cargo/barn doors. Now i CANNOT get these doors to shut properly. Ive worked three days adjusting those doors and i can get it almost there but the passenger side door sags in twords the middle line. Im loosing my mind! Im sorry in advance that i dont have pictures, its dark and rainy out. If ANYONE can please give me some advice of things to try.
Holl
Rich
suburban
what weather-stripping did you use? I used some from Steele rubber without issue. were the doors aligned without sag before?
annettemarie
Annette
It’s the weatherstripping from LMC. The doors seemed fine. They shut but it also had no weatherstripping so I’m sure that makes a difference. If you don’t mind telling me the weatherstripping that you used.
annettemarie
Annette
Also some holes for the pegs were too large or had been repaired with Bondo. So the stripping was a pain.
matt r
V2500
Any solutions to this problem? I’ve got the LMC weatherstripping and now the doors won’t close. Seems like there is a common thread here though: LMC weatherstripping maybe too thick?
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I used the LMC weatherstripping on my doors and they do close/latch, but I do get a small drip right at the top center when it rains and I don't seem to have enough adjustment on the body side of the latching mechanism to pull them in all the way, and sometimes I get a slight rattle which makes me feel like they need to close more but I have the adjustment all the way in.
zapattack
