Tire/wheel recommendations
Racer 238
idaho
Ben
My only point was that the term "offset" is just a waste of time when searching for wheels. Backspacing is what is important. Let's just say OP is looking at all sorts of wheels, 16x7 through 17x11. The amount of allowable backspacing is a set distance, you can only go so far. So if searching through all the various wheels available, do you want to do math for each wheel to figure out which offset may or may not fit, or do you just want to look at the backspacing spec?
As I said earlier, 4" +/- 1/4" is a pretty safe bet when giving advice on the internet. You can get away with a little bit more, depending on 1/2 ton, 3/4 ton, 1 ton, wheel diameter and composition. So if someone really wants to stuff as much wheel and tire as they can under their truck, they need to get out and use a tape measure to see how much backspacing they can get away with.
Yes, backspacing and offset are basically the same thing. But, one requires math to know if it fits your needs and the other one does not.
Oh, and even the factory narrow (15x6, 16x6.5 and 16.5x6.75) steel wheels have around 3.75" backspacing or so.
I ended up ordering 16x10’s -25. The specs say they have a 4.50” backspacing with 315/75 16’s. Hope they fit.
Craig 85
Nashville, TN
454/TH-400/NP205
Sorry late in the game here. The grey/silver truck was my '79 K15 that came with an old/stiff Rancho 4" lift. Back then it was wearing 15x10" wheels with 33x12.50x15's. The front fenders were trimmed when I purchased the truck. I went to a 4" Tuff County EZ Ride lift when I did the 3/4 ton axle swap. Tires were 33x12.50x16.5" and the wheels were old school 9.75x16.5". I believe those wheels had 4.75" of back spacing. Those 33" tires were actually 32.8" tall. With the softer suspension, I had no rubbing issues, but I think a 35" tire with that wheel would have.
My '85 K30 has a 3" lift, equals 5" on a 1/2 or 3/4 ton due to the frame height differences. Tires are 305/70R16 (32.8" tall) and 16x10" wheels. These wheels have 4.5" of BS. I would guess I could run a 35" (315) tire without it rubbing.
SquareRoot
Offset is usually described in metric too.
Guess we could describe a 17x8 wheel as 43.18cm x 20.32cm :rofl:
If God wanted us to use the metric system he would have given us 10 Apostles instead of 12! On the other hand, I'd be happy to show you my 9mm.
Ford used those metric "TRX" wheels in the 80's. They flopped.
It's funny how the metric system is so easy, but it seems like an insurmountable task to get everyone to use it.
Racer 238
idaho
Ben
new wheels just touch the tie rod end. Otherwise clears the fenders just fine. Any recommendations on spacers?
I would just grind the tie rod end, just enough to clear. It won't take much.
Racer 238
idaho
Ben
Mr Gasket makes some thin ones. Just make sure your lugs are long enough.
That’s probably what I’m going with since I don’t need much. Looks like the thread length on the front axle studs is only .93”. Do you know who makes the extended length studs? I can’t seem to find any online.
Craig 85
Nashville, TN
454/TH-400/NP205
Years ago I purchased them at Napa Auto Parts. Hopefully you have one nearby.
bryanedge117
