Rear End Gearing
The Lost Texan
Up North
Shane
LS
1985 SWB with a LS3 6.2 and 4L70. Ordered a 9” rear end from Quick Performance. Does anyone have suggestions on the final gear for cruising, in town driving and road tripping on the interstate. I will not be drag racing or auto crossing. Just cruising 50-70 mph. I understand tire size is a factor, however, I didn’t know what these particular engines like for RPM’s. I was leaning towards 3.50, maybe 3.73. Anyone have opinions or feedback? Thanks.
Keith Seymore
Motor City
Keith Seymore
4.3L
Hopefully you are not in a big hurry.
I ordered mine back in November and the parts are just now starting to trickle in.
(I'm not in a big hurry).
K
LS engines make peak torque higher in the rev range (usually around 4k or so), so don't fear a gear. I've got a ~425hp 5.3 and it used to have a 4L65 behind it with a 3000 stall converter (got a T56 now) and I went with 3.90s when I did the 10-bolt. That was the PERFECT combo IMO. Cruising at 70 I was right at 2250 with a 28" tire. Still nice and relaxed, exhaust wasn't singing but it would stay in OD/lockup even up hills. But then especially with the stall, it would get rowdy when you wanted to lay down on it. Perfect middle ground IMO. I put 27.5k miles on that setup and never once regretted the gear or wanted more.
3.55 or 3.70 would give you a nice comfortable sub-2k cruise RPM but it may come out of lockup more than you'd like. I personally would never go taller than 3.73. 3.90 or 4.10 would get my vote
Fat 454
Australia
C20 Suburban
We were looking to bring down the peak torque for an ls swap using a different cam, but after further study can see it needs to be rear end gear ratio, as the cam will not change the power band v. rpm relationship. Rear end ratio is therefore everything, ( and don't forget to measure tire diameter ).
Freiburger does a good summary as a starting point here ( hope this works ).
GorillaHumper
