A Technical Comedy [Only After the Fact]
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Every vehicle I have has a hidden set of keys, problem is finding them. So Kelly where you located. I am near Naches or Selah.
Turbo4whl
Downingtown, PA
Wayne
CRAP. The truck was running, I hadn't unlocked the passenger side, and I had no key for the passenger door, aside from the one in the ignition. PANIC
This here handy little gizmo works really well for wing windows: https://store.z-tool.com/products/wing-window-tool
So, every early square comes with it's own door unlocking tool. As long as the hood is not the cable release type (option on early squares) open the hood. Remove the bail wire that holds the brake master cylinder lid on. Snake the bail wire under the vent window rubber, twist it around and pull the vent window latch forward.
The bail wire works just like the tool Sad Sack posted. Newer squares take 1 second longer, you need to pull the release button in with wire tool before twisting the vent latch.
Dejure
Eastern Washington
Kelly
C15
SNORT. I used to live in Naches, back in the fifties. My parents owned Whistling Jack Lodge, but my mom couldn't deal with the seclusion the winter brought, so we moved to Naches and my dad stayed with his state highway job [eventually taking charge of the east side of the Northcross, when it opened.
Interestingly, the brochures the current owners promote don't show them as part of the history, but also shows the lodge as being built significantly later than it actually was.
Anyway, I'm an hour from Yakima, near a place called Mattawa.
We are, literally, in the middle of everywhere. We can go northwestish to Wenatchee, northish to Ephrata, North-eastish to Moses Lake, eastish to Othello, southeastish to the Tri-Cities, or westish to Yakima and it's all around an hour to those versions of civililization.
We only get to the Yakima area a time or two a year. All our shopping is done in the Tri-Cities.
Elvis2025
