JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Picked up as close to a match as the local hardware store could get. They are not exact lengths and the heads and washers are not exactly the same size either. If need be I will saw down to necessary length. I also ordered the Motorman used GM TBI hardware set from Evil bay, and my nephew is going to look for another injector system at the county autoparts scrapyard when he goes on Sunday. New gaskets also on order from Amazon. So between all of it hoping to get stuff back to install by early next week. We will see if the hardware store match is used or if the Motorman set gets here in time and are a match. Original GM on the right, hardware store match on the left.
Redfish
Prairieville, LA
Andrew
V1500
Also, the matched hardware are Allen not Torx.
I have had surprisingly good results shopping for bolts/screws/fasteners from Lowe's. There is an Automotive section in the bolting and I have been able to replace several fasteners over the last few years that looked just like what I removed and lost from my GMC(s).
Ajax19
Socal
Ajax
Haven't done much been working on non square body stuff, Picked up a winch plate and wireless remote supposed to rain next few days got a few things I want to do to the 75 before I start mounting the winch on the 83, 100$ for winch plate and Remote and 320 for a 12k winch I think that's a smoking deal
dustinova
Portland, OR
Dustin
C10 Stepside
I picked up an old, well used metal box that I'm going to use as a bed mount toolbox for my stepside. I'm planning on having someone local do some pinstriping work on it to make it stand out even more.
I believe you have a special Lowe's. Now, I gotta give them credit, they have improved their hardware selection greatly in the last few years. But for automotive type stuff, I've had way better luck with the average small town type hardware stores. Most have a great selection that's like 70% of what anyone could possibly need. Every now and again, you come across one that simply has everything and it's so damn impressive.
That's gonna look awesome in there!
Got the rear of the Blazer almost welded in. Did get the posts down on the floor where they belong. I'm must have done it correctly because the bolts lined back up where they belong.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Removed the wire i had on temporarily to keep the throttle cable from slipping off and replaced it with the correct clip. Google said auto zone had them but it lied. Had to get them from Amazon.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
These critical pieces aren't inconsequential. As my wife keeps reminding me, "It's the little things."
I'm hoping she's talking about attention to detail. :confused:
Strick
Dunn, NC
Harold
C20 Crew
Drove Hillbilly Deluxe home from school today & I'm more than satisfied with the ride from the 35 Patagonia & Rough Country 6" lift. Those came from a parts '91 Sub that I bought almost 2 years ago. Still have many things to finish but the project is coming together nicely.
kac0206
