Dual tank reads backwards
tzoftx
Franklin, TX, USA
Tim
C1500
Just aquired a 1986 GMC 1500 with factory dual tanks. I have replaced both sending units, selector valve, and selector switch. I have checked the wiring for any tampering, none. When I push the switch to RIGHT, it switches to the left tank and visa versa. Any help would be appreciated.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Is it reading the fuel level from the correct tank, but drawing from the other tank? Switch on right, drawing from left, showing fuel level for right? Or reading and drawing fuel from the left tank when on right?
If it’s reading the correct tank but drawing from the other, swap the hoses at the selector valve (both feed and return assuming it’s a 6 line switch).
1lejohn
texas
john
k-1500, 2500 HD
I would think that the wiring going to the new switch is backwards, (reversed), or the wiring going to the valve is wrong. It could be someone replaced the parts in the past and got it wrong. I would switch the wiring at the switch to see if it corrects the problem. The good thing is that the switch works. You could just change the label on the switch. :33:
Jgonick
West Texas
Joel
Wiring diagram
SquareRoot
Turn the switch over. Drink beer. Carry on.
tzoftx
Franklin, TX, USA
Tim
C1500
It reads and pulls fuel from the appropriate tank. Just switched to R it switches to L tank and visa versa. Thanks for all your replies. I don't drink.
ivangf
Mexico
Roberto
just interchange the light green with the dark green harnesses from the tank switch and that is it to avoid cuts in the middle of the harness
BrokeDaddy
