Wiring Harness? Choosing one?
Jordan Goodwin
Lobelville, TN 37097
Jordan
Looking at complete wiring harnesses for my ‘85 k30. American Autowire lists only one complete option on their website for an ‘85 chevy truck- their “classic update” kit, MSRP $1,069. Classic Industries has this same harness listed under “Universal Harnesses” for $883. Haven’t priced it anywhere else just yet. LMC does not have that specific kit, but does have an AAW harness “designed specifically for your vehicle”, that appears to have just a couple slight differences, don’t know what the difference is in plug and play abilities. That harness is $1,016.
I’m planning to keep this truck mostly stock. Which harness is going to be the easiest and quickest to install? Is there another option that’s easier?
Tonimus
Phoenix
Tony
C10 Suburban
Tonimus
Phoenix
Tony
C10 Suburban
Keep in mind that I'm a cheap son of a gun, too. The wiring harness in my race car is basically the cheapest AAW kit you can get. But I did their kit in my '84 C30 when I had it and that was one of the easiest kits I've done. And I've done too many.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Unless your stock stuff has been burnt up or badly damaged, I recommend just tidying it up and staying stock. The GM harness and fuse box is every bit as quality as anything available on the aftermarket
Doppleganger
OH-MI: Just like it sounds
I almost bought the OE replacement Painless kit - $700ish. What I wound up getting was a Painless kit for a GM column (the hardest part IMO) for <$400 as I am replacing the entire harness myself with relays, etc. Even had many more circuits for adding power windows, locks, etc.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Agreed! Even if you’re starting from scratch, you could buy a couple good used harnesses and build one far cheaper.
Jordan Goodwin
Jordan
Not sure what you were seeing, but I see the $1,016 at Classic Industries. https://www.classicindustries.com/product/1985/chevrolet/k30/parts/510706.html
The classic update kit is mostly plug and play and replaces nearly everything. It's a nice kit and worth the extra money, IMHO.
Bummer, yeah that exact listing is in their newest paper chevy truck catalog that I JUST got like a week ago, and it is listed for $882.99. But as their policy states, prices can change anytime and the most updated price is the one on the website. Quite a price jump.
Jordan Goodwin
Jordan
Thank you for your replies, gentlemen. I debated how much to put in my OP, but I guess there are a lot of factors I'm trying to weigh. Overall, I am trying to minimize cash cost to some extent, but time is probably most valuable to me these days, and while I don't want to shotgun money at this thing, I really also don't want to be constantly fighting electrical issues, or spend weeks rebuilding what is there if it would take significantly less time to do a total rewire- that said, y'all are inspiring me to look closer at what I have, but up til now it has been pretty discouraging to say the least. It seems like every wire I look at is either broken, cut off, has bare spots, or the insulation is crumbling. And, due to lots of moisture in the truck as it sat in the trees for the last decade, corrosion is everywhere. Under the dash is a mess, and most of the fuses were corroded badly, some to the point they came out in pieces. The fuse block may be fine, but it is certainly going to require a thorough cleaning at least.
ali_c20
Austria
Alexander
C20, K5
I used painless harnesses for my wifes 69 Mustang and a friends 77 K5. Installation was easy. Instructions are good and the customer service replied within 12 hours via mail and answered a question I had.
Tonimus
Phoenix
Tony
C10 Suburban
If most of the connectors are good or you can be replaced with something else you have on hand, you could use one of the universal kits. Those are also excellent kits and are way cheaper due to the lack of connectors.
Steelbuddha
Central North Carolina
Jonathan
K20 (dump bed)
I used the Painless harness with 27 circuits in my '84 K20. Figured it couldn't hurt to have a few extra circuits available. Also used their premium Aramid fiber wire wrap package to try to bulletproof it a bit. It was a simple (albeit time-consuming) job. The Painless installation manual is excellent, too. I give the Painless product high marks. Just wish they made them for more applications.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
American Auto Wire harness for the 73 K20. I got the kit as it has all new switches, sockets, connectors etc, all things I was going to have to replace. CalSgt is right, stock is good, but at almost 72, time is waistin' away. All new electrical is soo nice. I have several crimpers, but my son-on-law electrician had the Klein brand and they are very well made and great to use, and WORK! I also used the AAW on the 54 chevy 3600, and will use it on the 64, NOVA.
Everybody keeps pointing to painless,I haven't used them,but I do know from other people's posts they back dated the headlight circuit about 30 years. They went with a fused headlight circuit,not a problem 99 percent of the time. I don't want to be the 1 guy who losses headlights at 75 mph due to a blown fuse. GM went to a circuit breaker to protect headlights,decades before these trucks were made for safety reasons,a short in the headlight circuit results in blinking headlights,not loss of headlights. It would be easy enough to wire just that one circuit as GM intended, and use the painless harness,but you should be made aware of the issue.
Nardulli
St Louis
C15
I bought a different kit first and it was useless in a lot of ways.
I ended up with the following for my 86 GMC. The crimpers were key. This kit was straightforward.
Order summary​
Classic Update Kit - 1983-87 Chevy & GMC Truck × 1
$1,069.00
Double and Single Crimper Set × 1
$184.00
Subtotal
$1,253.00
Shipping
$37.95
Taxes
$77.13
Total
$1,368.08 USD
Total paid today
$0.00 USD
DollarBill
