K5 K10 17x8 or 17x9 vision Cheyenne Aluminum rally wheels?
TDoc
Flagstaff, Arizona
Terrell
K10, K5
The 16x8 AR172’s on my 79 k10 - Unfortunately the offset isn’t correct and the fronts hit the drag link. Used 5mm (3/16) spacers up front and the drag link clears just barely. The inner clip on wheel weights hit the drag link so I can solve that by going to stick on wheel weights. I’d like to go to a 8mm spacer but the 7/16 front lugs are so short. I’m getting 8 full turns with my extended thread lugnuts and 5mm spacer now but not sure if 6 turns with a wider spacer is enough?
On a 7/16's stud, you want at least 7/16's of thread engagement.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Even with my extended lugnuts, is this as simple as measuring 7/16 from end of wheel stud, mark it. Count the turns until I hit that mark, then mount wheel and hopefully I get the minimum amount of turns determined earlier.
The internet says 8.5 turns for a 7/16 stud. I’ll double check that with measuring.
mrchevy
