Whip antenna for CB on a Suburban
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
Hey all,
I know there have been a few threads out there, but I was hoping to get a little more feedback/guidance, and pictures if possible.
Long story short(sih)... I bought an '89 V2500 sight unseen off of FB Marketplace and road tripped it back home to Ohio with my brothers during the covid era. We wanted to take scenic routes, and it was a Roadkill-esque type trip, so I bought the CB supplies and we installed it, but I never tuned it or used it (the Burb never let me down!). I had the 102" whip antenna mounted on the bumper, which I know isn't ideal, but it was about the best I could do with the limited tools available. I sold that Suburban to my uncle about a year later to help pay for school.
A couple of years back, I found an almost identical '89 Burb V2500 out of Colorado that I couldn't pass up. I want to keep this one, and I also want to eventually make it reliable enough to be more than a weekend warrior. I bought a Cobra 29LTD, 18' of cable, and a ball mount, barrel spring, and 102" whip.
As far as I can tell from what I've been researching, the 102" typically has the best performance, but of course that depends on how it's mounted. I mostly want the CB in case I'm out in BFE and have a breakdown or emergency with no cell phone service, so the longest possible range is desirable (as far as I can tell). I know it may be dated, but I've also always loved the look of the whip antenna on square bodies (maybe because of the CUCVs).
The middle of the roof is the best place to mount it, but being a 102" antenna, that could be problematic. Is my best option just on the side of the Suburban, accessed by the taillight? I assume the metal there along with the backing plate on the ball mount is sturdy enough? It's certainly not a mint condition low-mileage Suburban, but it pains me to think about drilling holes in it- it's pretty clean with bumps, and dents, but only a couple of small rust bubbles.
Any advice/guidance is appreciated.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Yes, the rear quarter panel by the tail light would be the best location to put the ball mount. Like you said, it’s not ideal, but it’s the best location for that type of mount. And the 102” whip is the best antenna out there for cb, since that’s actually the ideal size for the wavelength that cb radio operates on. Me personally, I wouldn’t drill those holes, but it’s your truck. I’m also not sure how much I would rely on a cb in an emergency. There’s not a whole lot of activity in my area, but it may be different out your way. It’s definitely a period correct add on for the burb though, so you do have that going for you lol. You mentioned tuning, so I assume you know about SWR and the meter needed to check it?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Mount or make a mount on the edge of the rear bumper, then have a loop on the roof for when not in use. Otherwise I would make a reinforcement plate and slide it inside behind the sheet metal. By the twilight.
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
Thanks for the feedback! Right. Not a huge fan of drilling holes like that.
Good point. It's definitely a last-ditch effort, I see way more CB usage out west than I do on this side of the Mississippi. Maybe it's mostly for wheeling/off-roading to talk to spotters, I'm not super familiar with it, though.
Hahaha, I do like the looks of them, so that's also some motivation for this style instead of a more convenient antenna. Yep, I think my radio has a SWR calibration meter, but I also have an external one.
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
Thanks! I have considered it. I may need to get a longer cable, but no biggie. I could probably sneak the cable out of a barn door and make a mount (CUCV-style) on the side of the bumper, but I'd be losing a couple of feet of height above the roofline. If it's on the side, it would largely avoid contact with the barn door opening.
I have some scrap titanium and scrap stainless that would probably work. I guess I just have to do my best to get it as close to perpendicular as possible with the ground, as I understand you want a mounting surface that's as flat and perpendicular as possible. And I would definitely loop it to the roof rack when not in use.
Personally, I couldn't drill the quarter, that thing's too clean. Especially for an occasional use thing.
Google "CB mount behind tail light" and browse the pics. I'd fab up a bracket like this to utilize the tail light mounts or rear door mounts or something so I don't have to drill sheet metal
Fight Milk
Columbus, Ohio
Kelly
V2500 Suburban
Good idea, thanks!
Maybe I can make something like this work
Turbo4whl
Downingtown, PA
Wayne
Yes, this is correct. The reason for the center of the roof is to transmit best, you need a ground plane. the flat roof is good for 360 degree transmissions. Reception is not an issue. With the antenna mounted on the rear fender, transmission will be good out front and okay front left. Transmissions to the rear of the truck are poor at best.
To fix this, a second whip antenna on the right front fender. Not very convenient up front. So a quality center roof, base loaded antenna is a better compromise for 360* transmission.
Back when cell phones were just for rich people, carried in a suitcase, a CB was us regular folk. In my new 1974 Jimmy I bought all Hy-gain equipment. Transceiver, 18' cable and 102" whip, ball and spring. I mounted the ball mount right where you are planning, left rear corner with a plate. Yes, I drilled 4 holes in the fender of my brand new truck. I would have used a center roof antenna, but the roof was fiberglass.
This CB kicked out front! As stated, poor to the rear. A proper ground plane is as important as a good antenna.
Note: The internet also did not exist, I bought a book.
legopnuematic
Licensed Junk Dealer
MO
Spencer
You could go extreme by going the ways of a keydown rig :)
Get a couple of tuned linears... D&A Phantoms or White Tornado 225 ;)
Turbo4whl
Downingtown, PA
Wayne
Is that some kind of divining rod that pulls the Suburban towards radio signal?:rotflmao:
Interesting info. I had a CB in my '05 Z71 in college, all of us 4wd guys did. I had dual fiberglass firesticks behind the cab, mounted to the front of the toolbox first and they didn't work well. Then I got a 102" whip, 6" spring and mounted it to the rear of the toolbox on an L bracket. As you said, it worked great out in front of me but never behind and I never knew why. Never really did bother to research, now it makes sense.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I use to be big into radio when I was a kid. My fascination started when dad bought a Buick Electra with factory am/fm and built in CB. I was probably 6 or 7 years old. I have had a radio in every truck I have owned.
Back when I had disposable income, I use to snowmobile a lot. We used Cb to talk between trucks. There were usually about 10-15 of us that would go on the snowmobile trips, that means 3 or 4 trucks with trailers. My wife didn’t care for the radios, her solution was hand held walker talkies. She didn’t realize how many batteries it took for a 8-10 hours trip, not to mention the limited range.
This is a picture of how I infuriated my wife! The truck was about 6 months old when I did this. As big as modern trucks are, there is little space for accessories. My wife calmed down once I told her I had already bought replacement parts from a junkyard for the stuff I cut and modified. I can easily make it look like it was never there.
Anyway, this is my setup. I have a Wilson 1000 mounted on the roof. The Wilson antennas are set up so you can easily remove the mast. There is a little plastic cap that threads onto the magnet to protect the contacts. When I need or want the radio, the protective cap comes off and the mast goes on. The Wilson 1000 is a long antenna, and my truck sits high so it does bang into things. Taking off the mast when not needed is the best option.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I used to use CB's a lot when I did more road travel, and when I lived in Virginia and had a boat on the bay. It was (and still is) illegal to use a marine VHF radio on land without a license (but legal to use on the water), so I always had both a CB and a marine VHF on board so I could communicate with people back at the marina (or just for more mundane chit-chat and leave the marine frequencies open). I still have the CB's, don't have a vehicle antenna at this point and since pretty much all my stuff is solo now, theres not anyone to talk to.
cahillasher76
