Sliding Window Restoration Tips Please?
Art Vandelay
New England
Art
OE or aftermarket?
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Sam, did you ever rehab your rear sliding window?
The directions @SirRobyn0 gave are what I plan to follow for mine, but it also appears that there is some rubber/old black silicone that has cracked and pieces fell away on the exterior of the non-moving glass. Maybe I can remove the crusty and cracked pieces and lay down a new bead of silicone caulk there?
SirRobyn0
Well it worked for me anyway and my slider is still going strong. The rubber / silicone thing you mentioned, You could probably get away with some kind of sealant where you are talking about, but generally it's urethane used on glass not silicone, of course I realize we are talking about a rear slider not a windshield. If it's glass to the metal frame of the slider you can probably get away with using what ever you want. Feel free to post a picture of that stuff if you want.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I air sprayed the dust out of the channel, cleaned with alcohol wipes and q-tips, then sprayed some double u dee 40 silicone spray to lube the track and it's doing fine. I probably should hit it up again here soon.
