Sgt Gus
- Aug 2, 2023
- Texas
- Mark
- R20 3/4 ton
- 454ci/7.4L
Pic when you can. I was going to either put a connection or gauge underneath near fuel filter.My boy and I dropped the tank to swap the sending unit and pump. Then snatched the TBI off to add an adjustable regulator, gauge, pod spacer, rebuild and a TBI Spacer. As well as a fully open air filter with lid. After throwing it together I dialed up the fuel to 12.5psi and runs rather well. I am considering changing the injectors out and doing a grind on the ports. Will see how I feel at a later date.
