Rear Window size question
Chris64
San Diego
I'm looking to replace my rear window for a 1974 K-20. It has a slider. I don't know if it's factory. I wanted to change it to a solid window.
Everywhere I look it's called a "large" window. They approx. the glass size to be 16"x64". The problem is that is beyond the size of the outer edge of the rubber by about 1/4". I would expect the glass to be about 15" x 63" or smaller.
When I look for the small window, it's really small. 12" x 38".
Am I probably safe with the large window? Any recommended sources?
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
Have you tried calling a glass shop? LMC has listings for glass. GM made millions of these trucks. Should be a no brainer to find glass.
Local glass company will be best because when you pick it up you can check the fit right there. If there is an issue they can see it. I doubt you will have a problem with glass shop.
Chris64
San Diego
Yeah I tried a couple glass places. Their suppliers don't have them.
LMC has it and charge more for shipping than the glass but I guess that's to be expected.
There are no "large" or "small" back windows in these trucks. They're all the same size as far as solid glass. There are differences in the sliders however. GM sliders use the same gasket as the solid back glass, aftermarket ones typically use a different gasket. But the opening in the cab is all the same. The only squarebodies that got a small back glass are medium duty trucks
So you'll need this if you want tinted glass:
This if you want clear:
This gasket:
The trim:
Keith Seymore
Motor City
Keith Seymore
4.3L
Agree.
K
Auburn, Washington
If it’s a decent slider you could probably get someone to trade you for a solid window. If you were closer, I would.
Worth mentioning I’m almost certain someone, Precision maybe, finally makes new weatherstripping for sliding windows if that’s the issue with yours. (For the sliding panes, not the big installation gasket.)
Also fwiw, the rear window installs pretty easy. Way easier than the windshield.
Chris64
San Diego
This gasket:
The trim:
I just got a one piece rubber gasket (no groove). I may live to regret that. I've done this before on a Toyota so I'm familiar with the process but I'm sure the fit won't be easy.
ANTvenom
