Crew cab sheet metal replacement
79crewcab
Butterfield
Trevor
K20 crew cab
6.0l LS
I am replacing the floor pans with new cab support and inner and outter rocker panel as well as the kick panel and I am now trying to figure out the order as which they install any help would be appreciated i bought the replacement floor pans not the drop in style
79crewcab
Butterfield
Trevor
K20 crew cab
6.0l LS
Ill update my own thread as I learn the process
Started by removing rusted floors, rockers, and kick panel then proceed to test fitting after test fitting i cut out and welded the inner rocker to the floor pan
79crewcab
Butterfield
Trevor
K20 crew cab
6.0l LS
Pulled bottom of b pillar back to replace rotten floor and inner rocker sheet metal and welded passenger floor in
Bowtie-dad
Wyoming
Brad
V35
7.4l
Looks like your doing an awesome job and in the right order. For added protection there is a weldable primer for in between if you have any overlapping pieces or over reinforcements.
alex1992
