Vbb199
B-rate Hillbilly Customs
- Jan 12, 2018
- Salisbury NC
- Vince
- 89 Suburban R1500, 79 C10
4.10
Definitely on par. A nice clear day with no wind and the truck will do whatever you want pretty much without unlocking the converter.I have 350tbi/4L60/3.73 in my burb with "33's" that actually tape out around 32 inches. it is adequate enough that I won't likely regear but will look to add about 50 more hp when the engine dies. really it isn't bad on the highway cruising around 2100 RPM at 74-75mph flat ground. it does unlock the converter on mild hills and downshift on more significant hills, but it doesnt seem that much different than my 2004 burb, honestly. what really hurts drivability is any significant cross/head wind. that really kills it on the highway and I usually back off the speed a touch to help. I do about 15k miles a year in mine, with over half that spent on the highway between home and the farms (300mile one way).
if I was in a position with 2.73 gears and was going to regear for sure, I'd be a tough call between 4.10 and 4.56, with a slight nod toward 4.56 probably. that'd put me around 2400rpm cruising at 74-75.
I'd play with the rpm calculator with actual tire sizes and see what you think you want based on the engine's power band.
Wind affects these trucks pretty bad, and at 60+ mph, then they turn into a dog, especially with hills.
If anything it's liveable. Especially if you're not doing long interstate road trips. Highway is usually fine, the hills can get annoying but, $2000 minimum to regear isn't a small thing for most people.
That's my problem as well didn't matter if I was going back the way I came a few hours earlier, seems like the wind is always blowing at me lol.Yep, with no headwind and a flat interstate, it's fine. I was never so lucky though. It seemed like I always had a headwind and was going up some kind of incline on any interstate trip. Just like grandpappy had to walk to school, in the snow every day of the year and it was uphill both ways, lol.
I liked the 04 burb comparison above. Super relatable. Our 08 Tahoe was definitely more powerful, but smaller, newer and lower mileage.
Also it's not apples to apples, but my old daily (06 Colorado with 5 cylinder) stock 31's was SUPER comparable to my burb on 35's. That's why I've been completely fine with the 3.73's 700 combo. The 06 was better on interstate holding speed but not much. Just about as bad in the wind. But of course the burb feels better down low and in town. PLUS I'm getting the same mileage if not a little better than the mini truck... that was over 260,000 miles too.
I assume with a fresh mild 350 and 4.10's, I would be completely satisfied for my usage. For a suburban that wouldn't do any real towing. A truck that I would daily plus tow with every now and then, I would go 4.56's.
Is there an in between from 4.10-4.56? That seems like that would be the ticket.
I figured as much on the in between.there is a rare 4.30ish something, but it isn't commonly available. with 32-33in tires, that would just about put it like stock tires and 3.73s.
I bet 35s and 4.56 is probably close to a "stock" gearing/tire size for 3.73.
Not according to the GM Heritage vehicle info kits.Someone mustve swapped the 700 in, a 2.73 wouldve been paired with a th350
Man, I can't imagine how sluggish the engine would be in .70 OD with a 2.73. And with the converter locked up -- forget about it!5.7 auto truck was OD trans only. And only 2.73 or 3.08 gears.
Ya doesn’t make sense and I could be wrong but lotsa crazy stuff in the 70s/80s in the name of emissions and fuel economy.Man, I can't imagine how sluggish the engine would be in .70 OD with a 2.73. And with the converter locked up -- forget about it!
I would have guessed trucks with 700R4/4L60 transmissions would have had 3.42 as standard.
Edit: I just now remembered renting a Chrysler product from Hertz (or whoever) back in the late 70s/early 80s. When that thing shifted into top gear, the entire car would shudder and the engine would clatter. Absolutely horrible! I still remember driving around everywhere except the freeways in 2nd gear.
Like the 2.14 ratio available in the 7.5” ten bolt axles.lotsa crazy stuff in the 70s/80s in the name of emissions and fuel economy.
Back in the day I had an 81 C10 with a 305 and 2.56 gears, and thought that was tall!Like the 2.14 ratio available in the 7.5” ten bolt axles.
Pinion is almost as big as the ring gear, but I think the land speed guys like them.
The gearset I away was for a G-body car with a 7.5" 10-bolt. But my 82 C10 also had 2.73, but 350 engines came standard with 2.56. Mine was a originally a 250-six.2:73 gears ??.... Never heard of a cheby truck with those
