Oil pan off, anything I should do while I’m under there?
Truck82
Alderton
Christopher
I have my oil pan off for a new gasket and was wondering if there is anything I should do, check, or look for while I’m under there? It’s my first look at the bottom end of this engine and I’m very surprised that it’s as clean as it is.
Truck82
Alderton
Christopher
If it’s really old or high mileage maybe consider slapping a new oil pump in it.
Can they be rebuilt/refurbished? It might not even be worth the money if they can
Auburn, Washington
Not to my knowledge. But quality ones are well under $100. And if you have Advanced Auto parts nearby may get one for like $15.
That said, knock on wood I’ve never lost an oil pump in a lot of old high mileage small blocks. They get gradually lower over time. If yours is running 50-60psi cold and 30ish hot at idle it’s like new. Have run many that were half that.
Truck82
Alderton
Christopher
This engine has great oil pressure. I run 60-80 psi all day
Truck82
Alderton
Christopher
Rear main, timing set and associated seals/gaskets
I’m doing the rear main but don’t know how far I want to go with the timing chain and all. I’m planning on building this engine in the spring/summer so I think I will leave that alone for now.
Carb'ed Vortec 350
Yeah may as well wait. The rear main is easy enough because you're already there. Oil pump is fine too if you're rebuilding the engine in a few months
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Just seal it up, save the money on the oil pump as they last almost indefinitely. When you rebuild (if keeping the same motor) pull the pump apart and inspect it. Get a good book on the build. I like the 454 way more then the SB, would never go back.
SirSmartyPants
Northern Virginia, USA
Ron
Probably a dumb question, but can the oil pan be removed without pulling, or at least raising the engine?
75BEASTK20
B.C. CANADA
Cal
I always tack weld the pickup so it can't come loose.
CodycodyCody
