How many bolts hold the transmission on and where?
grummy
Midwest
C1500
Do it a few times in a week and it gets real easy ! I did an (1) out, in, (2) out in and an (3) out in all in a week while I was "checking" used transmissions. I'm 65, and I did it myself. Yes, LONG extensions expose the top bolts once the rear of the trans is lowered a bit.
I used to do them with a floor jack, but I tell you, my buddies Trans Jack (like in link below) made it much, much easier. If you can find or rent one rather than using a floor jack, do so ! Jack the truck up as high as you can get it right off the bat. Use good jackstands !
Don't forget to have a small hydraulic jack and some blocks to put under the oil pan so the engine doesn't hang back on the firewall, and it also helps for quick realignment on reinstall. Too, for reinstall, it can be helpful to put a longer stud in the midway holes for alignment that you can see better. Once slid in, get the top and bottom bolts pulled up, remove the studs and put in those two bolts.
Make double sure your torque converter is pushed into the tranny proper before pulling that tranny up to the belhousing. And, watch your wiring harness over the top so that doesn't get pinched. It's hard to see in there so look closely.
I don't even pull the transmission doing flexplates,I've written it up before,the condensed version is replace 2 of the engine to transmission bolts with long starter bolts,slide the transmission back on the bolts and you'll have enough room to R&R the flex plate.
GTX63
Tennessee
Ty
None of the housing bolts hold the transmission in place. Those are only there to dampen vibration and be broken off with the ears. The transmission is sealed to the back of the block with a GM factory sludge that can be replicated when reinstalling with cooked 10W40. A 3' pry bar and a strong right foot kicking or a 5 lb maul banging at the tailshaft is all that is needed. You can check facebook marketplace under "Used Turbo 350 for sale" for confirmation.
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
Be sure to get the right flexplate for your motor ..
SBC 400 & BBC 454 are externally balanced ... They have a weight welded on ..
blainc
