Winch Mount
Redfish
Prairieville, LA
Andrew
V1500
I appreciate everyone's experience on this!
What do you guys think about a front mount hitch/hitch mounted winch setup? Seems like that would increase the versatility of the winch a little?
There are pluses and minuses to every idea. I also looked at this option for the versatility but not on my '87. I never considered a front hitch on either of my trucks because of pure cosmetic considerations.
I considered this option for my '19 2500HD but rejected it because:
1. Heavy to move
2. Where do I store it?
3. How much space to store it?
4. How much cargo space I lose when I have it in the truck.
What you use the winch to do also matters. My trucks rarely get stuck nowadays but they are often pulling something heavy from someplace it should not be. But I still don't want to be struggling with carrying a heavy winch and trying to stab it into a trailer hitch in deep mud...just in case.
One thing that we tend to overlook is that the conditions we drive in, the terrain, the obstacles are not the same everywhere. I live in South Lousiana and our mud is thick, deep and bottomless. By contrast I love watching Matt's Offroad Recovery based in southern Utah and he mostly deals with sand and snow. Their mud is usually about ankle deep but very, very slippery. You have to use what works for your area and your intended use.
warrpath4x4
Prosser, WA
72 K5/ 79 stepside/ 1989 suburban
I always liked this one from ORD but it is spendy. There is a story on their page where a guy ran his suburban through a heard of elk at 55MPH, it was damaged but saved the suburban.
scenic760
SoCal
Suburban K10
Ain't that the truth!
So after a Craigslist search I may have a line on a used winch bumper...the guy doesn't know what it came off of though..do were these made with vehicle specific bolt patterns to mount them up or did they have adapter brackets?? or ??
Redfish
Prairieville, LA
Andrew
V1500
Warn built them vehicle specific. That pic has it on the tailgate of a dentside Ford so one might assume it came off a Ford...
warrpath4x4
Prosser, WA
Ford frame rails are a different spread than GM rails. however its not impossible to adapt it, one of my old friends ran a Ford Warn bumper on his K5
scenic760
SoCal
Suburban K10
Got it!
Nice observation from a bad picture btw!
scenic760
SoCal
Suburban K10
Ok…so the Craigslist bumper turned out to be a diamond plate backyard fab with no mounting brackets..
The more I look at what’s out there, the less impressed I am. The classic Warn bumper is probably the best thing I’ve seen so far.
I’m tempted to buy some 1/4” plate and fab one up, simple clean lines that flow with the front end and without some stupid a** logo branded on everything…I am so sick of everything being an advertisement
74Blaze
Nashville, IN
Gerald
K5/Blazer
I went with RLC Fabrication. Great quality, but they are bare metal when you get them.
Redfish
Prairieville, LA
Andrew
V1500
That is a great looking bumper and I only rejected it because I was worried it might be a little too modern looking...but I should have included it in my original answer. Thanks for reminding me.
scenic760
SoCal
Suburban K10
Don't pay good money for an ugly bumper.
Love the slogan...and your right they are a good looking bumper and just a little modern...I think this might fit my project perfectly!
Thanks Gents!
scenic760
SoCal
Suburban K10
Ok...I think I may have found a bumper within a decent drive but had a question on mounting the winch...it looks like it's either a Warn or knock of type bumper but I was wondering if/how the HF ZXR 12000 winch will mount to it? From the dimensions it apprears as though the diagonal pieces attached to the front winch plate would interfere with the sides of the winch?
Redfish
Prairieville, LA
Andrew
V1500
Those angle braces look like they will be in the way to me.
scenic760
SoCal
Suburban K10
That was my thought as well…would it frowned upon to cut them out and weld in some corner gussets with cutouts to clear the sides of the winch?
Redfish
Prairieville, LA
Andrew
V1500
It is YOUR Truck and it is YOUR bumper. Seems to me you can do whatever you like!
That front vertical plate isn't supporting the winch, it only holds the fairlead. There can be significant pressure on the fairlead if you have any side loading or the line is pointing up or down so that front plate has to be strong...but not nearly as strong as the base the winch is bolted to.
I am assuming you are going with that Badlands Apex? Synthetic or steel cable?
scenic760
SoCal
Suburban K10
Got it, makes sense!
Yes, I bought a Badlands Apex with the steel cable for it during the COVID years at what I thought was a rock bottom price but I think they have gotten even cheaper since...
carlotta
