Help with grinding/whirring sound!
SquareRoot
@SquareRoot, did you have this problem also? If so I am hoping you found the issue because I am stumped.
No but it's probably bearings somewhere in the drivetrain. Wheel, Axle or carrier. Do you have a 2 piece driveshaft? Also check brake drums for worn and out of round. Metal contracts when cool, expands when hot.
77firstsquarebody
Tennessee
Justin
GMC C25
350 V8
Turns out the noise was coming from the speedometer cable. I took it out and added some cable lube and the noise is gone.
  • Like
Reactions: WFO
kodyg86
