Rubber seal(s) on outside of spindle?
DonA
E. TN
Don
K-10
4.3 V-6
I have an '86 K-10
I'm going through all the U-joints and such.
There are some seals on the outside of the spindles:
I don't need the spindle, just the rubber, but I can't find it listed.
Any idea what to call this set to find it somewhere?
Thanks
hoagster
California
K10, 1500
5.3l
go to dennysdriveshaft.com you should be able to find what you need
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I got mine from Rockauto pretty sure. Those are technically axle shaft seals. Can search spindle seals too. I think mine may have come in a kit with the spindle bearings.
DonA
E. TN
Don
K-10
4.3 V-6
Ok, thanks.
I appreciate it.
nvrenuf
Mobile, Al.
I forgot to say that those kit part numbers I posted will have the 2 seals, the washer and the bearing. There may be a seal only kit available but I’ve never seen it.
jmoe
