New to the forum, but not to Squarebodies...
BigT
Selah, WA
Tim
Scottsdale K20
I grew up with Squarebody Chevies, as my dad had 3 or 4 of them over the years; I even learned to drive in a '75 1/2 ton 4X4 manual hauling hay bales. After about 20 years without one around, I recently bought an almost entirely cancer-free '78 Scottsdale K20 for my daily driver. Mildly built 350 w/ 4 bbl Quadrajet, TH400, NP203, and 4:56 gears!! Low, low!! I also have the build sheet, and it's almost entirely stock. Factory A/C (missing a bunch of parts, including the compressor), cruise control (transducer is there, but missing the rest), and the HC4 4:56 gears. The underside of this beast looks new!!
I could use some advice from you squareheads on a couple of things:
1. I know the gears came with the truck, since they are on the build sheet. I looked the truck up on the build option chart posted elsewhere on this forum, and it would appear that they must have been special ordered, as the charts say that gear ratio was only offered stock on the K30 one-tons. Since they were put on this truck by Chevy, does that mean that other rear-end components were likely beefed up as well, or could the 4:56 gears just be paired up with the standard 3/4 ton axles, etc.? I ask because I may want to swap both front and rear gear sets to 4:10s at some point in the future, but I'm not sure what all I will need to do that.
2. Come next summer, I will want to get the A/C working, and I ordered the whole OEM style shooting match from LMC to have on hand when the time comes. LMC did not offer all of the lines, however, as you can see in the attached diagram circled in red. Can you guys tell me what that part is and where I might locate it?
3. I also have no idea which compressor to get. I've never had one of these trucks with A/C in it, so I don't know what I am looking for. Is there one out there that uses the newest refrigerant, or are they all R134A?
Thanks a lot for your help in advance!!
Tim
PS - Yes, I know the grille is not the right one for that truck - it's already been swapped out with the right one, just haven't taken a new pic yet!!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA. Awesome truck.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
BigT
Selah, WA
Tim
Scottsdale K20
WFO
Texas Panhandle
Auburn, Washington
Tim
Wow! Ida kept the 73/74 grille style. Love those.
Someone must’ve put an older core support n stuff in it. As those grilles are not supposed to fit in 75 (I think ) and up trucks because they set deeper than the newer models.
New one bolt right in?
Regarding gears, even if it was special ordered I’m fairly certain the axle is identical. 14bolt full floater.
That said, 4.56 is almost un driveable unless you never get on I 82 and only take back roads at 55mph.
I have 4.10s with new 35s and that is prohibitive for freeway driving imo.
3000rpms at 70mph roughly is what I get, just not conducive for driving the open road. I’d strongly consider you think about 3.73s tops and possibly a little higher even if it’s going to be a go everywhere daily driver.
Auburn, Washington
Welcome from Oregon. Dig that visor stuff lol
Yeah, those Lund visors on this style truck look awesome imo.
Although I’m less in favor of them on 2wd trucks. Idk why but I think they look much more at home on 4x4s.
Keith Seymore
Motor City
Keith Seymore
4.3L
Tim
Welcome from the Motor City.
At your leisure could you please post up a pic of the build sheet?
K
Keith Seymore
Motor City
Keith Seymore
4.3L
PapaD
