Heavy vibration at highway speed under load
BRetty
Los Angeles
Franklin
All,
Per the title, my '73 C10 (350 sbc, th350c (but TCC not wired up)) has very recently started to vibrate severely on the highway. It seems to maybe start around 35mph, jumps up around 45 and is shaking/rattling through ~75.
It is only under throttle -- if I let off the throttle it coasts and vibration is gone, press the gas it is back. The freqency feels like RPM-driven. I have a secondary vibration also, the interference makes the sound surge and pulse. (This might actually be the 170 and 5 freeways natural bumpiness frequency.) Whatever it is, it keeps unscrewing and spinning out my air cleaner stud, all the way out.
A week or more ago, I thought I felt a low-freq thump at idle - felt like an out of balance condition, felt it while parked and also in motion. There was a distinct pulse in my exhaust I could both hear and feel at the tailpipe. That low-level thump is still faintly there, but sudden driveline vibration more pressing.
My first thought was U-joints. Sat, I took her to the shop on the corner with the U-Joints I had got months ago, but I had the wrong size. The mechanic, pretty lazy honestly, said the u-joints looked good. He suggested tires/wheels out of balance, although I don't feel it when coasting at 60. He (allegedly) checked the flywheel/TC bolt-up saw no cracks nothing alarming.
Last week I worked on carb/fuel line. I put a vacuum gauge on and it read perfect 19", rock steady. So steady it seemed suspicious. I also swapped out my alternator last week b/c voltage seemed to read low.
So reading other stores of similar vibration, I can think of these possibilities. Any input on probability of these will be appreciated.
-- Harmonic balancer
-- flywheel / torque converter interface
-- engine mounts suddenly crumped
-- transmission has shifted / trans mount
-- driveshaft may have lost a balancing weight
-- U joints are going suddenly
-- DIFFERENTIAL IS FAILING (GM 12-bolt)
-- wheels/tires/alignment/suspension (suspension needs a rebuild and all soft bits replaced, certainly)
-- misfire or preignition under load
-- timing is somehow farked.
Thanks for all the knowledge I have already gained,
BRetty
BRetty
Los Angeles
Franklin
Following up, the vibration under load/throttle, that stops when coasting, makes me think my differential is failing. I surely have almost 1/2 turn of slack/lash in the driveshaft and often a hard CLUNK going into reverse or forward from parked.
I'm going to pull the plug and check the gear oil and top it off. It was last inspected/filled ~3 years ago.
Hooper's Rear Ends are the best around, they are very up-front about inspecting and recommending service. If it sounds like the diff is likely the problem, I will take it to them tomorrow morning.
Worst case, total rebuild on-vehicle, new gearing, same axle tubes, they quoted $1,200.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'd say its rear end if the behaviour changes with decel
Everything else on the truck will persist no matter the load/speed/rpm im afraid
Rear end noises and failure is such an anxiety inducing thing lol
fast 99
Spokane, Washington
Really sounds like a driveshaft problem, balance, phasing, angles, loose bushing, ect.
SquareRoot
It's gotta be a wear item if it just started. Bearings or bushings. I had a very similar issue that took me months to figure out. A loose bearing on the output shaft of the t-case. I know you don't have a t-case but I'd surmise the same issue could happen with the output shaft of the transmission or the pinion shaft of the differential. And if you really have 1/2 turn of slop in the driveshaft, that's an issue. If the bushings are severely worn, it's possible the pinion angle is changing under deceleration. Typically the angle is 3 degrees off static and zero's out (or close to it) under load. And yes, it's under load at cruising.
BRetty
Los Angeles
Franklin
@SquareRoot ,
My understanding was that rotational slack in the driveshaft meant worn ring & pinion gears in the differential.
ETA: also, the condition of noise under load / no noise in coast, incriminates the pinion/ring interface?
When useless local mechanic had her on the lift, I thought the balancing weights cemented on the driveshaft looked less than totally cemented. Could I have thrown a weight?
So maybe the first move is to the transmission shop to inspect the tail and the pinion bearing and shaft? Caesar owes me a favor and I am leaking ATF anyway.
Thx,
BR
Bloodhound1981
MA
Rusty
C-10
I'm currently battling the same type of thing. 1981 C10, with a new Chevy Performance crate 350, a 1990 Corvette 700R4, and a 12 bolt posi with about 30k miles on it, which sat for about 12 years. Re-balanced drive shaft, new u-joints. No shakes at all until you get to about 67 mph. Then it kinda goes away, and then over 80mph it gets way worse. I re balanced the tires, re aligned the front end, changed the rear diff oil. Same problem. I finally brought it to a dyno shop and they confirmed it was happening on the dyno. Turns out, somehow, my transmission cross member was totally loose. Now it remains to be seen if the loose cross member was causing the vibration, or if the vibration caused the cross member to loosen up somehow. Hope to know soon!
BRetty
Los Angeles
Franklin
I am going to get the wheels rotated and balanced, order new U-joints (tricky, I think the front is 2x1350 and the rear is a conversion 1310x1350) and see if the transmission shop can get me in to inspect the tailhousing and the pinion/shaft bushing(s).
Also need to find a drivehaft shop to check weight and balance. I think my driveshaft is ~1.5" too short for the truck, there's a LOT sticking out og the trans.
BRetty
SquareRoot
BRetty
If it doesn't have much engagement and there is any wear on the splines that will also cause an issue. My unseated bearing resulted in about 1/16th of an inch in perceptible radial play. It doesn't take much to cause a viration.
  • Like
Reactions: WFO
BRetty
Los Angeles
Franklin
The tire and wheel balance helped, but the very heavy vibration at speed is still there. My "hot-rod" mechanic suggested I may be having a misfire -- but that doesn't explain why it's only at speed and under load.
I almost wonder if there is something wrong in my third transmission gear.
Going to clean up my plug wires and dial back my ignition timing a bi. I do have knock under load, esp up hills. Might try the old "water-spray-in-carb" tune-up today.
Agreed. The fact that it only happens under load leads me to believe the same.
Also, when there's a bunch of rotational slop in a drive shaft, folks always tend to blame the ring and pinion being incredibly worn. But the ring and pinion interface does not directly engage any axle shaft movement. They forget about the spider gears and cross shaft, which is a lot of little moving parts that are the final link before an axle shaft sees any movement. I bring this up because when you add up the wear from all those items, it can equal rotational slop at the drive shaft. Besides that, some differential lockers will have a lot of slop and it's completely normal.
suburbansasquatch
New Hampshire
Warren
V1500
I had the same thing happen with my Burb about 6 months ago. It ended up being the ring and pinion had worn out and started eating the diff. Pop the axle fill port open and check the fluid for glitter.
BRetty
Los Angeles
Franklin
I agree, I need to suck it up and get her to the rear-end and differential place. It's not so much the $$$$, more that I need to bethere when they open the rear up and evaluate; hard to get a 1/2 day off work... ;-(
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
1/2 turn slack in driveshaft!!! I would stop driving RIGHT NOW, cause that is really not right. get a new gasket and pull the rear end cover that will tell the story I bet, I can just see the filing filled oil oozing out. If this is a 14 bolt, maybe the lash adjuster backed off, can't think of another situation. Under pressure the gears want to "push" away from each other, coasting pulls in., hence quiet. You will ruin everything in there if that is the case and you keep driving it that way. Sorry for the gloom, just don't want you to loose $$.
BRetty
Los Angeles
Franklin
I had my transmission shop go over my th350 to see if that was contributing. My driveshaft slop is more like +-15 degrees at the diff. I had trans guys:
- Unbolt the TC from flexplate and inspect
- Re-bolt them after a 1/3 turn shift
- Check my trans mounting.
- Remove trans pinion yoke and check splines for wear
- inspect driveshaft U-joints
- grease pinion yoke when reinstalling.
-They reported nothing bad, replaced trans pan gasket.
- My engine mounts are shot.
My next move is to replace my clapped out engine mounts.
Then to take it to a driveshaft shop to see if some balance weights came unglued and escaped.
Then the differential shop for inspection and service.
I have a question about a longer trans pinion yoke, will start another thread about it.
Thanks for all the input so far.
BRetty
armchair
