Mud Tires
Hunter79764
Grand Prairie, TX
Suburban V20
If you're a kid with a truck doing kid with a truck type stuff, it can chew through tires pretty quick and cost a fair amount. I have a set of remolded tires that I'm relatively happy with from these guys (Treadwright). My dad bought a set from Tire Recappers, and they seem to perform fine, but do not look as good on the sidewalls as the Treadwrights. Price is right for me, so just throwing it out there. You can get them in a winter compound that's supposedly much better traction on ice. Being in Texas, I don't have much input on that, but thought it's worth a mention...
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Big Yellow has recap MTs on the rear duals and they look good on there. Those treadwrights look pretty good
Auburn, Washington
Thanks for all the suggestions. As far as the mud flaps go, they came on the truck and are one of my favorite parts lol.
Shoot, that truck is rust free for the salt belt! Beautiful rig! What part of Cheeseland you in?
Cooper Evolution MTs are a good mid price range mudder.
2toneK20
Wisconsin
Hobsen
k-20 scottsdale
I’m in central WI, but the truck was out of Montana. It was a 2 owner truck before I bought it and seems to be pretty well taken care of. I will look into those tires as well as the recaps others mentioned.
Normmus
Saskatchewan
Norm
You can get cheap army surplus 8.25-16 if you look around. They're heavy duty and around 33" diameter but skinny if that might be an option
Zelph
Nevada
If you’re going to be in the mud look at some Goodyear drag slicks as they’ll get you through just as well as the thornbirds.
If just going for looks the thornbirds will be ok.
2toneK20
Wisconsin
Hobsen
k-20 scottsdale
Yeah mostly going for looks. Most of the only mud it will see is in fields and driving around the farm.
Auburn, Washington
Cool. PS those vintage mud flaps have some value. Some were reproduced. WA and MT aren’t afaik.
JD Miller
Goober Idaho
JD
K20 silverado
Get some Intercos
2toneK20
Wisconsin
Hobsen
k-20 scottsdale
Get some Intercos
I would like to, but my rims might not be wide enough to mount those tires up properly. Their website says minimum rim width 8 inches. I have not measured mine but I’ve heard most steelies are 6 inches.
Dooley
North Coast
RW
V30
255/85-16's on stock 8" wide rims.
No lift.
Never rub.
BFG Mud Terrains
Is there value in a single vintage mud flap? Or only as sets?
They also make a great entry mat to a shop or garage entry door. So I'd say there is some value.
Scribbles
az
It's great to see a High School age driver of a vintage truck. I probably wouldn't display your front license plate...but I graduated high school in a different century.
This probably isn't exactly what you are looking for but I am running Cooper Discoverer STT Pros on my '87. My factory rally wheels are probably a bit wider than your steelies.
I run those on my 90 Burban and I love them up in the mountains and even a few feet of snow up on the backside of Crown King AZ.
Doug Hampton
