Question on upgrading gauges
Beercelo
Tucson
Raul
On my 82 C1500 I currently have the gauge cluster that is blank/empty in the bottom left corner and I'd really like to have the clock that came on some models, but I want to keep the original look, I'd like to get a donor cluster like this one from ebay or a junkyard with a clock on it and getting new gauges from LMC, since the only things that work are the speedometer and the gas gauge. Anyone know if this is do-able and easy?
ali_c20
Austria
Alexander
C20, K5
I did it for my 74 C20 cluster. It had idiot lights, ammeter and no tach. I used the Lmc gauges. I put in a tach, small fuel gauge, voltmeter, electrical oil pressure gauge and temp gauge. It's all plug and play, you only need the matching printed circuit which is also available from Lmc.
Rickf
Grafton NH
1974, 1954 & a 1937
A used clock without a "guarantee to be in working condition" can be a crap shoot. Plus think about what is the newest used gauge cluster, 30+ years old? I've purchased several gauges & printed circuits from LMC and never been disapointed.
hoagster
California
K10, 1500
5.3l
Some one did a lengthy write up redoing their cluster! I'll find it,
there you go!
Beercelo
Tucson
Raul
Definitely Lmc for the gauges, yeah I had a Monte Carlo many years ago and went thru several used clocks, none of them worked, one came off a 74 Camaro that I saw with my own lyin' eyes that it worked in the Camaro, when I put it in my Monte it petered out for some unknown reason.
An original cluster with tach would put a fuel gauge in the lower left and a tach where you now have your fuel gauge. Looks very balanced, and there is no clock to go bad.
Auburn, Washington
That’s what I’d do if I was gonna drop some $ on replacement gauges.
The last working squarebody clock bit the dust in 1993 probably …lol.
I got 2 of them. Every other gauge works great. Both clocks probably been dead since 1981 and 1990 respectively.
tmssldn
