Discussion and Opinions on 83'-87' Builds
Coop8202
Charleston, WV
Austin
Hey guys, looking to buy a 83'-87' Single Cab LWB 4wd 4 speed and do some work to it.
Plans are built 350, 1 ton axles, small lift, exhaust, stacked headlight swap, etc.
Just looking for opinions from others who may have done a similar swaps or recommend certain motors or upgrades. Maybe even post their build.
Open discussion!
Auburn, Washington
My opinion, why the 1 ton axles? Assuming you’re looking for a 3/4 ton already, are you wheeling it to the point that the front 10bolt will break or loading the payload over the capacity of a sf 14bolt? Otherwise a D60 and 14FF will be of zero net benefit.
Don’t take this the wrong way, but sounds like you’ve just been browsing the web and found some cool words that you don’t understand but think will make a truck cool.
The real question is what do YOU want out of the truck? Otherwise suggestions go from bone stock classic car show winner to mud buggy on 44s and many things in between.
Yeah, what's the planned usage for the truck? Also as far as the quad lights are concerned, just buy a truck that's already got them.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
A k20 is generally cheaper than a k10 or k30. You'll pay the most for a k30.
I would say if you want a 4 speed manual, I would stay away from 85-87 as those will have hydraulic clutches and parts availability is usually not good, or really expensive. A mechanical clutch will serve you well and there are way more of them and replacement parts.
Dmack
Central OR
Dave
My 83 K20, 4sp, 350, 4" lift on 315/75R16
Rusty Nail
Rusty
350sbc
It costs more than you think.
Centerbolt cylinder heads or nah?
83-87 is no good range.
81,82 83,84,85 are all one thing but 86,87,88, are different trucks.
Mmmkay
That's all too new anyway.
Think in the 70s.
'77 was the last good year- then they changed the frame and it was all downhill from there.
73-77
Mmkay?? :)
Hope this helps!
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Get a solid K20, make all the mechanical stuff work good and do the cosmetics later. The times when our trucks and parts for them were cheap are long gone.
496bb
AL
CL
Suburban R20
Welcome from Bama!!
I agree, what's the usage? If towing or need HD, I'd rather have a big block than a 350.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
Auburn, Washington
Mmmkay
Think in the 70s.
73-77
Mmkay?? :)
Hope this helps!
I know the OP hasn’t returned but maybe you could explain your opinion about some of these things you say are no good.
Center bolt valve covers? Lol. If Having or not having those is a reason to not buy a truck, that makes about zero sense. That’s pickin fly sht out of pepper.
83-87 no good? Can’t even begin to understand what you’re referring to there.
Different frame after 77 no good? Same as above
Combining my recent few years owning and comparing similar condition 70s and 80s models, there’s precious little different between the 2 in the grand scheme. Appearance is the biggest difference for the most part. And that’s just preference not a material difference in performance, reliability or technology.
From the 80s and 90s when I looked after a fleet of work trucks some of which were 70s square and others 80s, the only marked difference I recall was the 80s models were at the age and miles where the “new emissions crap” was part of the required repairs or getting tossed in the garbage, lol. That and the “new” TBI engines were a dream compared to carbs and reliable. But now that is all old hardware and subject to needing work and slightly more complicated than a carb.
IMO, 90% of finding a “good” Squarebody or any old car or truck is the condition it is in. Especially the tough or costly or frustrating stuff to repair or restore. Like in-tact factory wiring that isn’t mouse chewed, rotted out from 20 years of winter salt and brine or the product of someone who loved scotch locks and numerous electrical “modifications.”
Irregardless of what may or may not have been a little quirk either way back when the vehicles were relevant. The other 10% is, does it have what YOU want that is of value to YOU. IE being running/driving may be important to one person, but another has a fresh 454 sitting on a stand and could care less whether it has a running greasy 350 under the hood or not. Or you have a couple cherry doors in your junk pile so caved in doors are not a detriment or cost to you.
And as always JMO.
Cheers!
2manysquares2care
