Where does this go???
WV85square
United States
scott
It's a 85 k10 custom deluxe.
Auburn, Washington
Cig lighter or dash speaker?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
What about heater/ac panel lamp?
Illumination wires are typically grey IIRC
@75gmck25 is correct, constant hot should be orange
Green wires are typically associated with cruise control and A/C IIRC, I know several GM cars use green for the A/C compressor switch wire
That's a front speaker connector.
WV85square
United States
scott
Makes sense. Truck doesn't currently have center speaker. Thanks
The truck will either have a speaker in both ends of the dash, or the center speaker. But not both. I don't recall which location used those colors, but I do remember that the lighter shade of green is the ground.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
Left and right end speaker plugs have an angled connector though.
I can't tell in your photo if that hardshell connector is straight or bent at an angle.
aubiexx
