Just picked up an LT4 swapped '86 C10
I believe they're 3.08s, which are not ideal but I'm running a th350 so probably the best compromise currently. I may looking into an OD trans in the future (potentially 700r4) with some better gearing in the 3.40-70 range, but TBD on that.
Since you already have the EFI and whatever computer running the LT4, you might as well just drop in a 95-newer 4L60e instead of a junk 700R4. They are basically the same trans, but with a bunch of reliability improvements in the 4L60 and no TV cable since it is all electronically controlled by the computer. It also lets you easily adjust the trans shift points and lockup with an OBD2 tool.
F51 LRS
SC
Joe
LT4 350
That's a good shout, too. I haven't put a ton of thought into the trans just yet - I'll probably leave well enough alone until I decide to figure out all the wiring for an e trans.
Rusty Nail
Rusty
350sbc
Well , this IS the internet....and it requires pictures to operate.
Last I checked
Hold on!
There's no smoking tire/burning rubber/action pix?
Wtf.
I dunno about you, dude. It's fascinating that your next move is to make further and even more unverified claims?
You ain't got no more pictures??
I don't believe it.
Tell em AL!
* ;) i like ribbin new guys, thanks for bein a sport. Thanks @Turbo4whl.
Have a good seat pal.. I'll send The Drink Girl over
I bet that sucker is a handful... no doubt.
It leaks oil? You gotta fix it.
We'll get ya squared away.
Get it?
Squared away?
:rolleyes:
Oy vey @ Noobs
Squared away??
F51 LRS
SC
Joe
LT4 350
Last I checked
Hold on!
Wtf.
I don't believe it.
Tell em AL!
Get it?
Squared away?
:rolleyes:
Oy vey @ Noobs
Squared away??
:favorites13: The ribbing I can handle...the bad puns not so sure lol
On another note - got the leaks all squared away....damn it, I just did it too... Redid the timing cover/water pump, oil pan, & trans pan. Tight as a drum now so had a celebratory shop beer & am allowed to park in the house garage now that it doesn't mark it's territory every time I park.
tbradish88
