texdave
- Mar 28, 2024
- texas
- tex
- C10
I noticed that my factory cruise control was not working on my 76 3/4 ton Suburban. I took a look at the 76 Supplemental shop manual to learn up on the Cruise system and seems like the major components are: the regulator, the servo unit, brake switch, and the column switch.
The brake and column switch are in place and seem to move fine. The servo unit looks damaged, see the pictures.
I couldn't readily identify the regulator though. Any tips on where it should be located? Also, I'm not seeing a servo unit part on Rockauto to replace this. Is that part not reproduced anymore? If so, any tips for how to get cruise going again? Thanks.
