Does any one know what had a similar banjo as this?
cbrown5385
Mass
Corey
Suburban 1500
Does any one know what had a similar banjo as this? Very hard to locate. It came off an 85 c10 but I can’t find the replacement
appears to be for hydroboost at the unit if i had to guess
cbrown5385
Mass
Corey
Suburban 1500
Bennyt
Surprise
Ben
I'd look for a line shop near you. They can make just about anything you need. A lot of them are mobile and build lines/fittings on the spot.
Robert Bare
MT
Robert
k20
Looks like front brake hose for a c10 with a diesel motor.
Rockauto has both, left and right.
CALLED IT, but sorta. I figured a hydroboost unit hose but that truck would have hydroboost, so im basically right.. right?
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Accuracy is sometimes off, but Rock, Napa and the rest have pictures of the parts which is so helpful these days. GL kiddo, let us know what you settled with.
Doug Hampton
