Trying to remove plastic knob on side vent
Gardendelite
King County Washington
Gaetan
Hello all, any idea how to remove the knob on the side vent? 1975 K10. Might be a better thread location. Let me know.
nvrenuf
Mobile, Al.
Seems like there’s a clip at the far end on the vent flap. Be careful with it, I believe those are discontinued and good one are hard to find.
Turbo4whl
Downingtown, PA
Wayne
Only early squares have the cable vent controls. Later models, the vent pull is all plastic. To remove the knob, remove the cable from the vent. Disconnect the loop of the cable at the vent door. The cable assembly is locked in the plastic vent cover with spring loaded fingers. Remove the screws holding the plastic cover over the vent.
Now with the cover and cable off, you can accesses the fingers to push the cable assembly out. Cut the rubber knob off with a hack saw, don't cut the metal stem. I did this so I could install my chrome metal knobs.
Gardendelite
Gaetan
Thank you to for the replies. I came to the same conclusion but the confirmation is good to know. Think I will tape everything and paint the kick plate in place. Seems like the lesser of two evils.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I couldn’t find a great picture but
The plastic rod hooks to a “u” shaped rod that slips through 2 holes in the vent flapper. Can’t remember for the life of me what the clip looks like.
The whole assembly isn’t too bad to remove from the cab, the upper screws are a little tough to get at and the foam gaskets can tear when you peel the panel off but gaskets are easily fixed or replaced
CalSgt
CA
Casey
Gardendelite
Gaetan
Interesting, yours came out as a complete unit. I am going to see if mine will do the same. Thank you!
Turbo4whl
Downingtown, PA
Wayne
@CalSgt
The vent doors on early squares have a cable
Geatan asked how to remove the knob from the cable. It is not removable, but the whole cable assembly can be removed.
Many metal parts of squares were changed out for plastic parts to reduce weight. Squares were designed when fuel was less than 40 cents a gallon. Government CAFE numbers forced all the changes.
Gardendelite
Gaetan
Thank you. I attempted to gently remove the knob but experience told me to give up and ask advice. Much of my current wisdom comes from bad decision making.
Cantrell299
