Fwiw
@Ricko1966, you obviously are a career mechanic and your wisdom and direction on this forum is beyond great. I’ve heard more “tricks” that I didn’t know come from you than all but a select few people I’ve known, past or present.
That said, most people aren’t professional mechanics and your scolding gets a little carried away sometimes. There more considerations to repairing a car than being 100% accurate in your diagnosis and replacing only the exact part(s) needed. Like time, ability, convenience. I’m not advocating breaking out the nuclear powered parts cannon everytime there’s an issue. But there’s a middle ground where those of us who don’t earn our paychecks with wrenches in our hands actually live. Keep that perspective in mind.
Cheers!
Sorry if it comes across as scolding,it's meant to educate. Some people don't realize changing parts,without verifying the old one is bad or the new one is good can really make fixing something harder. Especially when they post up with,I've changed this and this and this and this and this and this and it still doesn't run. Well, now this this this this and this need to be tested to make sure they are all good. The installation of this and this and this this this this. Needs to be checked to make sure that they were installed properly. I hope me saying this makes someone think,let's test the part I think is bad before I replace it. Especially a Newb that doesn't realize that changing random parts sometimes makes it more difficult,to diagnose the real problem.
Edit,I walked away and had to laugh at a real life incident, it's not just guys on here, lots of people including professionals,change things without diagnosing. This is why I laughed,this is true incident that happened at work one day. A coworker,changed cap,rotor,plugs,and wires, then had the parts dept. order all the same parts again. I said Jimmy! What are you doing you just changed all that. He says yea but it still has a miss in it. I asked did you run compression. No,they aren't paying me to run compression. We'll they aren't paying him twice either,his logic worked for him,but not for me.
