Steering Wheel Cleaning
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
How do you get 40+ years of gunk off of a steering wheel?
Many years ago, when we were getting the GM comfort grip spoked steering wheels from the local Pick Your Part's, we had a plastic washtub that was large enough to dip them in. We'd keep it about half full of Simple Green and water(I think 50/50 mix, don't remember but it probably has suggestions on the label). It got all the wheels clean, though some did require some scrubbing due to grime in the texture of the vinyl. Some of these wheels were so grungy you couldn't tell what their color was....
On the factory leather wrapped wheels on my OBS trucks, we use water on a towel, or a wet wipe, depends on what type of grime is on it.
Gunk, or the goo that comes from the degrading old rubber/plastic that the wheel is made from?
I usually either install a steering wheel cover, or replace the wheel. But I did not want to replace the original wheel on my '73 wagon. Iirc, I scrubbed it with glass cleaner and a terry towel several times. It feels 75% comfortable now.
ali_c20
Austria
Alexander
C20, K5
I had to replace the steering wheels of my K5 and C20. Both where degrading and sticky like the hands of a 3 year old kid after eating cotton candy.
Cleaning only helped for like a week.
Ken B
indiana
ken
thanks , will try to scrub and see how it turns out.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Used some Dawn spray foam on one yesterday. Worked fairly well.
mlsceo
Kingsburg California
Manuel
Dawn, warm water, and a fairly stiff bristled brush. Helps to wet a towel with the soapy solution and wrap it on the wheel for a bit before using the brush. Softens up the grime.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Skin oils and dirt are only part of the issue. Plastic, particularly the softer kinds, has oils in it that degrade over time, especially in hotter climates.
Those wheels we used to clean with Simple Green, we used to scrub them with plastic net like fruit bags, it's one of the few materials that won't abrade the vinyl too bad.
junitor
