Should I replace?
kenneth1669
oregon
Kenneth
I burnt up my th350 and am in the process of rebuilding it with the help of YouTube. I forget what it’s called but it’s all burnt to a crisp and the clutches look like they have sat on a BBQ for a couple hours. Would I be able to clean this out or does it need replaced?
NickTransmissions
Las Vegas
Nick
Take the piston out of the forward drum then thorougly clean and inspect it. Once you have done so, if there is no structural damage, bluing or other concerns like worn input shaft splines, it can prob be reused.
For your reference:
Also check out my TH350 Information thread on here - link is in my description.
kenneth1669
oregon
Kenneth
@kenneth1669 - Why did the forward clutch get so burnt up like that? What was the direct cause?
The truck was sitting for 7 months at my grandparents house and it leaks a lot. Brought it home and forgot to check the fluid and burnt it up. That’s what I’m assuming at least. I went to check the fluid after it started having problems shifting and it smelled very burned and very black
NickTransmissions
Las Vegas
Nick
Hmm..not likely you completely burnt it up as described by failing to check fluid level, unless you have reason to believe it was leaking and low to begin with. I ask as the forward clutch is always applied when you're in a forward pattern range position (Drive, D2 and D1 aka Manual Low) so it's not often we see that clutch pack burnt...Inspect the lip seals to see if they hardened as that would explain it (sitting for months, especially over the summer time) can potentially allow the seals to harden enough to only partially seal when put to work after the long break.
The stator sealing rings may have also been worn as well...Whenever you see anything like burnt frictions, especially in a non-working clutch pack, it's always a good idea to determine what specifically cause the clutch to fail (i.e. the direct cause) so you know there's not an undiscovered problem somewhere that will still be present when you put the rebuilt transmission back into the vehicle.
kenneth1669
oregon
Kenneth
Weird I’m not sure. The lip seals looked alright just old and not terribly dried out. The truck was sitting for about 15 years in a storage unit with that transfusion in it. The previous ownwr had the original 400 swapped for the 350. I have only out about 750 mile on it sense resurrecting it from the storage unit.
kenneth1669
oregon
Kenneth
Hey I thought instead of making a new thread I would just ask here but. I’m in the process of putting stuff together and my rebuild kit didn’t come with the 2-3 accumulator piston seal. The little piston in the valve body. I think that’s the name of it. I can’t for the life of me find one. Do you guys have any idea where I could find one?
NickTransmissions
Las Vegas
Nick
One should have been included in your paper and rubber kit aka overhaul kit - perhaps double check....Also, if the 2-3 acc piston you have is plastic, replace it with an aluminum one.
If you still cant find it, any local transmission parts supplier will have one for you.
JUKA
