Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
A couple of basic questions about adding cab lights - devil's in the details as they say.
Got these mounts:
One on the left is a GM original. One on the right (hardware store) is the same thread and size (trunk is a tad thicker) - but rubber instead. I like the rubber one but it would require a larger hole to be drilled. How does the stock metal GM one mount? (not 100% sure how the rubber one installs either). Does it expand like a rivet? Looks similar to those anchors they use for the door mirrors. I could dab it with panel adhesive if need be. Dunno.
Nuther question: what size /color bulbs do you guys use? Going LED of course - the 168 is slightly brighter than a 194. Also need to find a GOOD LED bulb - most everything is chicom - just need to find a better brand.
I mocked one up and was kind of meh on the output of the clear bulb with amber lense. No idea what an amber bulb would be like.
Just thinking out loud before holes get drilled.....
THX
Got these mounts:
THX
