Pinion shim help
nelio
orange county
nelio
chevy c10
I need to achieve the pinion depth depth of 2.751 from center bearing to the face of pinion . I’m currently at 2.733 do I need to add or remove shims ? If so does anyone know how much ? Thank you in advance
Rustisbest
Just the facts
Athens, TN
Remove .018 worth of shim
Rustisbest
Just the facts
Athens, TN
If this is the 12 bolt from your other thread start at a .030 shim.
According to Yukon instructions that's the nominal size. I've only set up 4 gearsets but might be able to help
goodwrenchca
