What is this please!
WFarm
Central Virginia
K5 Blazer
Can somebody tell me what this part is? It’s bolted to the inner fender on the passenger side on my 75 Blazer, which was originally a 350 engine. I looked thru the factory service manuals for the heating system but just don’t see it!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Not factory. Looks like a y fitting. Most likely for fuel.
Its part of the ejector seat option.The mystery toggle under the dash,opens a solenoid on a compressed nitrogen bottle,the bottle feeds through the bottom port of that junction,out the top port to the ejector seat. You're missing some components.I know at least a few of our members have the mystery dash switch. You guys need to team up and find the rest of the components.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Whatever it is, I wouldn’t trust anything on a truck that new that’s bolted on with a slot style pan head fastener.
That screw belongs on yard furniture from the 50’s
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Electrical trim faceplates?
CalSgt
CA
Casey
Heater core bypass maybe
Olegmbuilder
Denver,colo
Esteve
k5
shortshift
Seattle
If those are fuel line size then i seem to remember one on a van that was used for the return fuel line to tank
motoxrrar
tennessee
robert
I took it off today and saw one word on it: Moroso. So googled Moroso and found it. Then tossed it.
Did that have dual tanks at one time ? Probably used to feed two tanks to the fuel pump.
WFarm
Central Virginia
K5 Blazer
One outlet was plugged so not sure what the purpose was with one inlet and one outlet.
thomasjm55
