Wiper switch/signal stalk
91burb2500
Plantation, FL
Joey
Suburban R2500
My wiper switch jammed in the column and can no longer activate the wipers. Before I buy a new switch and stalk (no writing left on it), is the LMC stuff any good? They’ve always been hit or miss with the stuff I get there, but their prices on these particular parts are about $125. Online auto parts are around $165 for both, seems like the same stuff. OEM is $150 just for the stalk and it’s made in Taiwan too, so just figured I’d throw it out there and see if anyone had any experience with these?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I'd say the switch is the issue, but, if you are there the stalk makes sense, too. Mine is not set up like that but I recently bought a Standard stalk off Parts Geek, I believe, for my 99 Camaro . This has the cruise switch and was roughly 60 bux IIRC.
91burb2500
Plantation, FL
Joey
Suburban R2500
I agree the switch is bad but the stalk is cheap and might as well since the chrome is starting to lift and can’t see any of the markings.
brentjo
