3M Tape on cab moldings
miguelt4
California
Miguel
I have a 1981 That has no cab moldings at all not even the holes where they go has anyone every used 3M tape if so how has it hold up do you happen to have any pictures thank you.
Shorty81
Baby Boomer
North West ohio
Darren
I used 3M tape for my badges 10 years ago, they are still holding strong.
legopnuematic
Licensed Junk Dealer
MO
Spencer
3m VHB- Very High Bond tape is what you want.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
You can get the factory style clips and use sheet metal screws to attach them to the back of your cab. Drill the holes for the corner moldings...
Auburn, Washington
Yes. I was thinking side moldings when I posted. But the Op hasn’t been back to his thread to confirm.
When I put the rear cab band on the 86 (weird it was a fully loaded truck with about every option except that piece), I thought about trying to stick the clips on with vhb tape. But decided I didn’t want to test my theory and just drilled the holes.
miguelt4
California
Miguel
Tailgate C10 Yes. I was thinking side moldings when I posted. But the Op hasn’t been back to his thread to confirm.
Yes I was taking about the cab molding the one below the rear window and side of cab
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
They make special trim screw you can use to put the molding clips on if you desire to go that route. They would take the place of the little posts. Same as for windshield molding. You can get them on ebay cheap.
WWOLFE68
Ontario, NY
Wes
1979 & 1987
K10 & R10
Any link or part# for the trim screws referenced above? I purchased NOS 3 piece cab molding and small.tailgate band for.my 79. Really want to just use 3m vhb tape but nervous of going that route
Auburn, Washington
I think the back piece cab molding would work if using the plastic clips. The corner pieces need to be drilled and fastened with the nut though. Plus if the tape fails it won’t fall off as it’s also retained by the corner pieces.
Idk about the small 70s tailgate band. Depends how much surface area you have for the tape to contact. I know it won’t work for the big tailgate bands.
brooksman9
Olive Branch, MS
Patrick
350 & 305
drewdavis83
