Slooptin
- Mar 6, 2017
- Denver
- Vance
- k30
Recently did a hydroboost conversion on my 90 v1500 suburban. Everything works as it should except the brake warning light on the dash comes on after like 3-4 minutes of driving. brakes feel firm and were bled after the install. The possible culprits I can think of:
1. I'm having is the pump whines every once in a while, but I can't see how that's tied to the brake warning light
2. Maybe I need to bleed the system again but I was pretty thorough the first time and it doesn't feel like there's air in the system
3. During install, I had the switch on the proportioning valve unplugged as well as the "ABS controller" mounted next to the master cylinder and those got a little bit of brake fluid on them. Maybe I need to replace the switch, which I plan on doing when I bleed the system
Can anyone provide any insight here?
