Mystery plug and wires
Cdog_96
Aiken
Clay
Hello all, I am working on 1987 Chevy v10 pickup and wondering what these connections are. This plug has a grey, pink/black, blue and green wire and someone put a spade connector to it with a cut wire. Other connection in question is orange and white wire that are stuck together, looks like the orange goes to constant battery on fuse box. These are also cut, what are they? Any help appreciated thanks
Jgonick
West Texas
Joel
Plug is part of cruise control & orange and white wire is probably dome light
orange & white wires are usually bonded together running towards the dome light
Bronze Knight
USA VA
Robert
Orang and white should be accessory lights. Well the whole accessory circuit is orange and white. It could be glove box light, dome light, cargo lamp, footwell lamp, door buzzer.
Cdog_96
Aiken
Clay
Thanks so much ! Where does that cruise control plug go into ?
Jgonick
West Texas
Joel
A wire (cable) runs from the turn signal lever down the steering column to it. The plug itself snaps into a metal bracket by the steering column close to where the brake switch is-if I remember correctly
Cdog_96
Aiken
Clay
Makes sense, thank you
OurDually
