ajwic1
- Mar 3, 2024
- Nelson, BC, Canada
- Alex
- c2500
- 5.7L v8 (350)
Hi there. 1981 c2500 pickup.
I have an issue with my drivers side marker light (facing outwards) that i cant seem to figure out.
When i turn left blinker on, the forward facing one flashes and the the side one DOESNT. (However the right side ones flash aswell!?!?). The rear work as they should.
Now in addition to that whenever i turn the headlights on (pull the knob out) the left front marker stays solid and once again side doesnt do anything. The dash also stays solid and so does the rear. And the right side stays lit also.
Right indicator functions as normal in both modes.
I have tried swapping them and confirmed the light is good. I used the test light pen and confirmed both sides of the connector has power. Multimeter was hard to get an accurate reading but it seemed low (less than 12v)
Has anyone experienced this/any ideas?
