Terry Wilkerson
- Dec 2, 2021
- Kansas
- Terry
- GMC 1500
The dome light isn't supposed to come on on door open??Yep, not an issue. I think that corner of the fuse block is Ignition. You won't have a dome light with the key off. BTW, there are kits with the original plugs that snap in place for cheap and they are color coded and only fit the sockets they are intended for.
It is but, the power comes from the battery not the ignition.The dome light isn't supposed to come on on door open??
Got it.It is but, the power comes from the battery not the ignition.
