What is this?
Terry Wilkerson
Kansas
Terry
GMC 1500
My truck is a 1986 gmc 1500 rwd. Doing a ls swap on it. What is this? It's underside of passenger dash.
Scott91370
Burleson, Tx
Scott
Sierra1500
ESC (Electronic Spark Control). You will not need it with the LS. HEck, if you had the small block with HEI distributor you don't need it.
Yep, that's the ESC box. It has a harness that goes out into the engine bay and connects to the dizzy. I ran my swap harness through it's hole in the firewall and mounted my computer in that spot since I have the smaller E40 computer
aaron06
