D70 spindle nut socket?
Girth
Olympia WA
Garth
V2500 Suburban
Finally getting around to tearing down the D70 that’ll be going under the wife’s Burb.
What am I looking at here? Need a socket for the spindle nuts (unless I wanna chisel it off) but this is a new one for me, with the round tabs. Only thing like it I’ve found is from Torque King, or do you think a standard 6lug square tab will grab that well enough?
Strick
Dunn, NC
Harold
C20 Crew
The square 6 should work fine.
Girth
Olympia WA
Garth
V2500 Suburban
Imho, if the square tabs fit in there, it'll do just fine.
Popped the snap ring, pulled the square key out, tapped it loose with a screwdriver. It wasn’t that tight. Now I have the nut to test sockets.
It’s a single nut, not the dual nut/lock washer I’m used to. Never torn down a D70 though, so yeah.
One drum off. Happy to see it looks decent, and hoping the other side looks the same. Progress. The Mrs will be happy. lol
Old Guy Bill
KY
Bill
I just went through that a few months ago on my 14 bolt.
Mine were in bad shape, I was able to get them loose with a punch.
I replaced all of them with the square ones that are currently available and fit my socket.
ksquare84
