dragstews
- Mar 27, 2024
- Belleview Florida US of A
- Jesse
- Body 1954, frame 1975
- R-100
- 406 ci SBC
Good grief !!
Well, it looks like I'm in for some more work !!
Using a column shift that was made for a TH400 ain't working out so well on the 4L80E trans ..
Moved the pivot on the frame to a new location .. That worked out pretty dang well ..
Modified the rod going from the trans to the column, that too worked out nice ..
Found out that the column didn't have enough throw to get to second or first gear .. Thought was to give the column arm more throw to catch those two gears ..
Column tubing was acting as a stop ..
Cut a notch in order to allow more swing of the shift arm ..
Creeping up on it .. Didn't want to over shoot the cut ..
Did a test to see how it would work and ...
Got to pull the column cause there's another stop internal that needs to be messed with ..
!! Lovely !!
Going to save that job for another day .. Do think the notch in the tubing will be enough ??
Really didn't want to go into the guts of the Caddy column cause it is working super well as is, but Que Sera Sera !
!! Lovely !!
